Old 09-04-2012, 04:43 AM   #141
politby
politby's Avatar
Originally Posted by Gforrest2 View Post
I can't remember which wire off hand. I found it someplace, just trying to remember where. I'll search around today. As for the splice. I used one of those clamps where you insert the splice wire in the clamp and close it on the wire you want to spice to. Probably should have just spliced and soldered it but I got lazy.
Glen
Thanks, great if you can find it.
I have measured the connectors and it seems pins 10 and 11 on the red plug are ignition switched 12V. They go to 12V when ignition is switched on but go back to zero when the key is turned back to the ACC position, which is not really what I want.
I prefer not to have to have ignition on to be able to run the radio. There should be a possibility to just use the ACC position, no?
I seem to remember the stock radio would remain powered until the doors were locked.
If only the pinouts of the a/c display were available somewhere...
politby is offline   Reply With Quote
