Old 09-03-2012, 08:24 AM   #140
Gforrest2
Gforrest2's Avatar
Originally Posted by politby View Post
I took out the a/c unit today and there are a LOT of wires on those two connector blocks. Which one is the switched 12V supply? Green/black?
Probing them all with the ignition on and off will take ages...
Did you put a tap on the wire or did you cut and splice?
I can't remember which wire off hand. I found it someplace, just trying to remember where. I'll search around today. As for the splice. I used one of those clamps where you insert the splice wire in the clamp and close it on the wire you want to spice to. Probably should have just spliced and soldered it but I got lazy.
Glen
Glen
Gforrest2 is offline   Reply With Quote
