Old 11-16-2005, 04:32 PM   #11
RandallNeighbour
The coolant resovoir is about $400 plus installation. Replace it if it's leaking or has cracks. Keep an eye on it if it hasn't gone out if you're broke. That's what I'm doing.
John Schilling here on this forum did his own coolant resovoir replacement and said it was time consuming, but not all that hard.
The transmission cables are not expensive... probably under a hundred bucks each, and I think you could DIY if you take your time and give it a go and do some internet based research. Pix are out there as to what they look like and how to change them out, IF they need to be replaced.
