Originally Posted by boxster6354
Momo has some great looking ones, keep in mind that you will need to round off the shifter to fit a knob other than OEM to it, not hard at all with either a dremmel or grinder bit on a drill.
You can get a sleeve to slide over the shifter with a set screw to accept round knobs and avoid doing this. There are some really nice ones at Suncoast but they are very proud of them. CF or root wood etc is around 400-500 bucks last I checked. Sunset is probably cheaper if you want to stick with factory shift knobs, unless you can find one on Ebay and they do come up. I got a root wood one for 100 bucks with some wear, but not worn out.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
