Old 09-02-2012, 03:01 AM   #135
politby
politby's Avatar
Originally Posted by tony_fury View Post
This is more than likely the switched power lead you are looking.
I don't believe it asks for a code, rather than a 12V trigger to the radio to present code on the display.
The code is internal to the radio set by Becker matching the model and serial number to the radio code.
Could be, but oddly enough it reads 11.6V, not actual battery voltage (12.4V on the constant voltage lead). Probably not safe to use as switched power for a head unit.
politby is offline   Reply With Quote
