Old 09-02-2012, 02:58 AM   #1
2003S
2003S's Avatar
There is also a position reset procedure you might try before replacing the top microswitch:
With the convertible top fully closed, press the up button on each window and then continue pressing down for about five more seconds. If that doesn't work, it sounds like the microswitch under the latch - you should be ble to test by just using a finger and feel it with the top open. There's a small switch that when depressed turns allows full operation. It may just require a little lubrication, too...
Is the "top in operation" dash light going off at all?
2003 Midnight Blue S
LN IMS Retrofit
