Good news on the fitment - you can carefully peel the rubber seal off and re-stick so it fits flush against the light and bodywork.
However, am having a few issues with the LED indicators.
When working on park lights or on dimmed beam they work fine, but on main beam or fog lights they flash very quickly, basically flash quicky when there is any load on the electrical circuit.
Remember I have rear LED brake lights and the third brake lights are also LED with resistors fitted.
Can anyone help with the above?
I'm thinking I may need resistors on the front LED's - Appreciate if anyone can confirm.
Tip for anyone it is easy to dislodge the existing cable connector on the car, especially if you are pulling the lights in and out when setting the lights up - I did!
