Okay - apologies for not posting pics through this walk through on fitment, but promise to upload some pics later today.
Okay, lets walk through the install and I am going to be critical, but fair!
Installation of bulbs is a little fiddly more me being paranoid not wanting to make contact with the filament itself.
Install into the car is easy - once you know how to dislodge the existing - their is a u-tube clip that will help - 996 headlight replacement.
The fit I would give 9 out of 10. The rubber seal isnt perfect against the bodywork, but unless you are specifcally looking for it then I wouldnt say it is a major issue.
The seal itself can tear so be careful!
Install simply slides in and locks into the existing wiring connector.
Once switched on my indicators were going haywire and I thought more resistors required (I have LED rear lights and a pair of 3rd brake lights).
However, once I started the engine every thing settled down and problem solved!!!!
I'l let the pics tell their own story, but these lights ARE AMAZING!!!!
They blend in perfectly and modernise the car - thoroughly modernise the car.
Personal opinion - black on black is perfect!
Once I post the pics I'll let you know if the auto adjust still works!
Be back soon
