Old 08-31-2012, 11:57 AM   #13
Cater
Cater's Avatar
Sorry, but that's not correct. If the AOS is gone then there are billows of white smoke and it is continuous, not just at start-up. This is just a little blue smoke at start-up and is probably nothing to worry about, unlike the AOS which, if gone, should definitely be worried about.
If there is a concern about the AOS then do the oil filler cap test to confirm or eliminate it as a suspect.
The smoke is only going to be there on start up if it's the oil separator.
My brother has had this happen with his car and It is a very common problem with Boxsters.
Cater is offline   Reply With Quote
