Old 08-31-2012, 02:03 AM   #130
BestGear
Originally Posted by politby View Post
Got it. Final question - where did you take switched power for the head unit, and how did you connect the parking brake/reverse leads?
Hi
Switched power is already on the ISO block so nothing to do.
The reverse was from the rear lights as I was already running a cable for the rear camera so was zero hassle. There is reverse signal in the ECU under the passenger seat if you dont want to run a cable to the rear boot.
Handbrake - did not connect it - just earth the wire and dont view movies when driving....
David
BestGear is offline   Reply With Quote
