Old 08-30-2012, 11:00 PM   #15
Eric523
Boxster Abuser
Eric523's Avatar
Originally Posted by Kroggers View Post
Thank you Eric, we have also had the same discussion on the front wheel fitment on another forum
But now that I know that it can fit, then question that is coming up here is if it is a good idea for me to go to a wider front and rear set-up or stay as I am - what do you think Eric?
For a 3.2L Boxster, I would want more than a 225/265 pair. A 245/275 would be nice and is available, or even a 255/285 with DOT tires. It does does depend a bit on the track you run, but I would always want more than a 225 DOT(or EU equivalent street rating) to get the most out of that car in the front. You are running almost Boxster spec sizes with another 100hp, and a bit more weight I believe. So I would expect the additional footprint could be put to good use.
Eric523 is offline   Reply With Quote
