Old 08-30-2012, 01:30 AM   #125
politby
politby's Avatar
Originally Posted by BestGear View Post
The secret, (if there is one!) is to put two screws through each side (holes already in cage) and into the plastic dash part just the same as the more expensive kit.
I did this - and added a couple of washers between frame and cage to prevent distorting the plastic frame.
This makes it very rigid and will never sag nor rattle.
You just need to mount everything up on the bench to get the distances right, then fix it in place within the plastic frame.
David
So did you use the cage that came with the Connects2 kit, or the one that came with the head unit?
I was thinking the Pioneer cage will fit the unit 100% but OTOH the Connects2 cage may be better adapted to the car.
My car has the one piece "horseshoe" vent frame and I am not sure what is the best way to remove it but I suspect is is just using clips.
politby is offline   Reply With Quote
