Old 08-29-2012, 07:43 AM   #10
shadrach74
Originally Posted by ginge View Post
Is this possible for it too snap just driving around a roundabout?
Doubtful, but anything's possible. I doubt the shaft itself is snapped, likely the joint at one end. I would have likely started making quite a racket long before it broke. Even if it was something internal to the trans-axle, it would have likely given an aural warning.
The majority of these cars do not have limited slip diffs, which makes them even more of a handful in the wet. It is not hard at all to break the rear end loose in damp/wet conditions. once it goes, if the driver gets off the gas, it just exacerbates the issue. The only chance of saving it is to modulate the throttle and steer into the slide. Not an easy task in a split second and not something you think about. It has to be a natural/muscle memory type of reaction and that only comes from practicing...in an area that is curb and obstacle free.
shadrach74 is offline   Reply With Quote
