So you did have to make some modifications to get things to fit. I wouldn't call shaving any surface off of a wheel rim to be a minor modification, though. It also helps substantiate what Johnny Danger was stating initially in that there will be contact between the wheel and the suspension/body with an 11-inch rear without some sort of modification.
Upon rereading some of what you've written I saw that you did indeed say that there were some minor mods and bolt-ons required. I was under the impression that you were accomplishing this without modifying anything and simply finding the solution in a narrower tire, so that was my mistake in following what had been stated.
I'm actually surprised that you didn't have to do more than what you listed to get that to work.
-O/D
IMSR + RMS
Robbins glass window top
