Thread: strut braces
Old 08-27-2012, 10:48 AM   #16
shadrach74
i guess the strut tower brace spreading issue is supported by the tension vs compression idea - thin aftermarket braces would combat towers spreading much better than they could withstand towers trying to come together. also supported by what i've seen on my car - on jack stands the strut towers appear to be spreading - shoulders drooping - as the front fenders are sitting lower than the trunk; this goes away when on the ground. variation between cars may be due to age = metal fatigue, driving surface, suspension stiffness (ie., how much force transferred to the chassis) and the witches brew that results when you combine all these factors.
Has your car ever been crashed? I have had my car on stands and on a lift and never had a problem opening and closing doors. I know of one 993 Carrera cabrio that had enough flex to prevent the doors from opening when it was on a lift. My Boxster is not like that.
shadrach74 is offline   Reply With Quote
