Old 08-25-2012, 09:16 AM   #1
The Radium King
The Radium King's Avatar
more aos thinking ...
so, folks have talked about dumping the aos into a catch can before - done often by racers (not street legal) avoids feeding oil into your engine upon failure, more notice of aos failure as you'll see oil build-up in the catch can. you you have to occasionally drain the can when it gets filled. here's a good option:
Stage 1 Single OCC
two issues with this approach:
1) crankcase vented to atmosphere, so not environmentally friendly.
2) no longer applying vacuum to the crank case which is a bad thing as engine is designed to have this vacuum to ensure ring seating.
so, has anyone tried combining the catch can with one of these:
TRM Tuning - Crankcase Evac Kit
basically it gets vacuum from the exhaust instead of the intake.
