Do some more checking before you run out and buy expensive parts.
When I was in automotive school, my instructor said a good mechanic will change what is broken, a bad mechanic will just start changing parts until he fixes it by a process of elimination.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
