Old 08-22-2012, 04:45 AM   #11
shadrach74
True. But, once you've removed the headers/pre-cats and replaced them with a cheap set of headers that have primaries that are probably no larger than 1 5/8 in diameter along with the even more restrictive 600 cell secondary cats still in place, what do think you'll gain ?
There is no reason to keep the secondary cats. Mandrel bent cat delete pipes can be had for under $250; the install should take about 2 hours. There is a lot of unrealized potential in the 3.2 that was deliberately left untapped by the factory. Porsche's marketing dept likely did not want the lowly roadster beating up on it's older more expensive brother.
shadrach74 is offline   Reply With Quote
