Old 08-20-2012, 12:33 AM   #1
tjbjday
tjbjday's Avatar
Over my head-help with jack stands
I have taken on the job of window regulator successfully. I am now trying wheel refinishing. Thought it would be nice to put wheel up in the air using jack stand to all turning wheel while sanding and buffing, since I was unable to break one lug bolt loose. I have the rear jack position on a jack stand. Front wheel is also off ground. I tried putting the second jack stand on the opposite side by jacking the front jack point up until I can get the jack stand under the rear jack point. I cannot get the car high enough. The car "levels out" and I and a half inch too low. Am I hurting the car having it up on only one jack stand?
tjbjday is offline   Reply With Quote
