Old 08-19-2012, 07:57 PM   #15
Eric G
Theoretical propagandist
Eric G's Avatar
For Fluellen as there was a request for the parts list...this is not all of them but what I purchased from Pelican:
Cam chain tensioner 900-123-147-30-OEM Sealing Ring, 27 X 32, each
Cam chain tensioner 900-380-019-02-M100 HEX NUT M8 X 1
Cam chain tensioner 996-105-017-02-M100 SHAFT BASE
Cam chain tensioner 996-105-180-57-OEM Chain Tensioner, For Intermediate Shaft
Cam chain tensioner 996-105-186-01-OEM Chain Tensioner, For Cylinders 1-3
Cam chain tensioner 996-105-188-01-OEM Chain Tensioner, For Cylinders 4-6
Cam chain tensioner 999-707-344-40-OEM O-ring, 18.77 X 1.78, Each
Clutch 012-141-180-B-M100 Guide Tube For Clutch Release
Clutch 012-141-719-E-M100 Release Bearing Lever, Boxster (1997-04), Each
Clutch 012-141-741-M100 Retaining Spring for Clutch Release Lever, 986 Boxster/Boxster S (1997-04)
Clutch 012-141-751-C-M100 Pivot Piece for Clutch Release Lever, 986 Boxster/Boxster S (1997-04)
Clutch 012-141-777-D-M100 Ball Pin for Clutch Release Lever, 986 Boxster/Boxster S (1997-04)
Clutch 034-105-313-A-M5040 Pilot Bearing, Boxster/Boxster S (1997-04), Each
Clutch 8E0-721-257-M-M5038 Clutch Slave Cylinder
Clutch 900-067-131-03-M260 Pressure Plate Bolt, 8 X 16 mm, 6 Per Car, 996 Carrera 2/4 (1999-04), Boxster/Boxster S (1997-04), Each
Clutch 996-423-171-06-M33 Clutch Master Cylinder, 996 Carrera 2/4 (1998-04), Boxster/Boxster S (1997-04), Each
Clutch 997-101-212-01-M17 Flywheel Seal, 996 Carrera 2/4 (1999-04), Boxster/Boxster S (1997-04), Each
Clutch 999-073-092-02-M260 Flywheel Bolt - M10 x 50mm
Clutch 999-230-541-10-M100 Union for Clutch Fluid Pipe, Boxster (1997-04), Each
Clutch I3020-377426-OES Clutch Fluid Hose, Boxster, From Chassis Number 98XS620221 To Chassis Number 98XU624362 1999, Each
Clutch N-903-542-01-M100 RUBBER O-RING
Cooling system 996-106-011-56-M244 Water Pump with Composite Impeller (requires one 996-106-340-54-M30 gasket)
Cooling system 996-106-013-59-M902 Water Thermostat, Low Temperature (begins opening at 160 deg F) with Cover and Gasket
Cooling system 996-106-147-08-OEM Coolant Expansion Tank, Boxster/Boxster S (1997-04), Each
Cooling system 996-106-340-54-M30 Water Pump Gasket, 996 (1999-2004), Boxster/Boxster S (1997-2004)
Engine components 016-311-113-C-M213 Main Shaft Seal for Manual Transmission
Engine components 987-375-023-05-M100 Engine Mount, One Per Car, Each
Engine components 996-105-325-52-M100 Spark Plug Tube (Note: Does Not Include O-Rings)
Engine components 996-107-023-04-M100 Oil Separator, Boxster (1997-02) 1997-99 models up to 1999 engine# 65X 01419 also use (1) 996-107-145-06-M100 vent line and (1) 999-707-446-40-M100 o-ring, Boxster S (2000-02)
Engine components 996-107-225-60-M45 Hengst (OEM) Oil Filter Insert (Filter Cartridge and Seal)
Engine components 997-602-107-00-M47 Ignition Coil (sold per each, 6 required)
Engine components 999-512-630-00-M100 Oil Separator Hose Clamp, Lower (35 X 12)
Engine components 999-707-215-40-M17 Outer Spark Plug Tube O-Ring, 27.94 X 5.33 (6 Per Car) Boxster/Boxster S (1997-2004), Each
Engine components 999-701-789-40-OEM Seal for Air Oil Separator (Inside Oil Sump), Boxster/Boxster S (1997-04), Each
Engine components OEM-99610715006 Genuine Porsche Part: OIL FILLING PIPE
Engine components 996-104-215-54-M100 Camshaft End Plug 6 Per Car, 996 Carrera 2/4 1999-04, Boxster/Boxster S 1997-04, Each
Engine components 900-377-011-01-OEM M10 hex nut, each
Engine components 999-072-008-09-OEM STUD M 10 X 30, each
Engine components 999-218-088-09-OEM 999-072-008-09-OEM
Engine components 999-707-343-41-M17 Inner Spark Plug Tube O-Ring, 25.07 X 2.62 (6 Per Car) Boxster/Boxster S (1997-2004)
Steering 996-347-131-04-M80 Outer Tie Rod End (sold per each, 2 per car), 996/996 Turbo (1999-2004), Boxster/Boxster S (1997-04)
Steering 996-347-191-04-OEM Tie Rod/Steering Rack Boot, for original rack #996-347-011-06 or #996-347-011-07 (2 Per Car, sold individually)
Suspension 900-380-005-01-OEM Rear Shock Absorber Mounting Nut, For Securing Mount to Chassis, 6 Per Car, Boxster/Boxster S (1997-2004), Each
Suspension 900-380-012-01-OEM Shock Top Nut, M14 x 1.5
Suspension 986-331-043-07-M80 Control Arm Link (Track Arm), Rear Suspension, Left and Right, each, Boxster/Boxster S (1997-04)
Suspension 987-333-059-00-OEM Rear Shock Absorber Mount, 2 Per Car, Boxster/Boxster S (1997-04), Each
Suspension 996-333-792-24-OEM Rear Sway Bar Bushing, Stock Rubber, 18.7 mm (sold per each, 2 required), 996 (1999-2004), Boxster (1999-03)
Suspension 996-333-792-25-OEM Rear Sway Bar Bushing, Stock Rubber, 19.8 mm (sold per each, 2 required), 996 (1999-2004), M 030 Boxster (1997-99)
Suspension 996-341-043-06-M80 Control Arm Link, Front/Rear Suspension - Front Lower, Left and Right, each, 911 Carrera 2/4 (1999-05), 911 Turbo (2001-05), Front - Boxster/Boxster S (1997-04)
Suspension 996-341-053-17-M80 Control Arm, Front/Rear Suspension - Lower, Left or Right
Suspension 996-343-069-04-M80 Front Sway Bar Droplink, left front: 996 (1999-2005); left front or left rear: Boxster/Boxster S (1997-2004)
Suspension 996-343-070-04-M80 Sway Bar Droplink (sold per each), right front 996 (1999-2005), right rear or right front Boxster/Boxster S (1997-2004)
Suspension 996-343-107-03-OEM Upper Shock Stop Plate (sold per each, 2 per shock), front 996/996 Turbo (1999-2004), front or rear Boxster/Boxster S (1997-2004)
Suspension 996-343-301-02-M58 Rubber Bump Stop (Bushing), Front Strut, 986 Boxster/Boxster S (1997-04), 987 Boxster/Boxster S (2005- ), Cayman/Cayman S, 996 Carrera/Carrera 4 (1999-05), 911 Turbo (2001-05, except GT2), 997 Carrera/Carrera S with M475 PASM (2005- )
Suspension 996-343-505-00-M737 Protection Boot for Front Shock Absorber Left/Right (2 Per Car)
Suspension 996-343-515-05-M100 Front Shock Absorber Mount, Lower Rubber Bushing, 2 Per Car, 996 Carrera 2 (1999-04), Boxster/Boxster S (1997-04), Each
Suspension 996-343-792-14-OEM Front Sway Bar Bushing, Stock Rubber (sold per each, 2 required), 996 (1999-2003)
Suspension 996-347-322-03-M80 Inner Tie Rod (sold per each, 2 per car), 996/996 Turbo (1999-2004), Boxster S (2000-04)
Suspension 997-331-045-04-M80 Control Arm Link, Rear Suspension - Rear Lower, Left and Right, each, 911 Carrera 2/4 (1999-05), 911 Turbo (2001-05), Boxster/Boxster S (1997-04)
Suspension 997-343-018-01-M69 Shock Absorber Mount, Front, Upper Plate (2 per car, sold individually)
Suspension 999-084-447-01-OEM Front Shock Absorber Mounting Nut, For Securing Mount to Chassis, 6 Per Car, 996 Carrera 2/4 (1999-04), 996 Turbo (2001-2004), Boxster/Boxster S (1997-2004), Each
Suspension OEM-98633328501 Sealing ring Brand: Genuine Porsche
Suspension OEM-98633330101 Genuine Porsche Part: SHOCK RUBBER BUFFER
Suspension OEM-98633350402 Compensating plate, 3,0 MM Brand: Genuine Porsche
Suspension OEM-98633350501 Genuine Porsche Part: SHOCK BELLOWS
Suspension OEM-98633350902 Genuine Porsche Part: SHOCK MOUNT RING
Suspension OEM-99634351100 Compensating plate, 3,0 MM Brand: Genuine Porsche
Suspension OEM-99634351101 Compensating plate, 6,5 MM Brand: Genuine Porsche
Suspension OEM-99634351300 Cone washer Brand: Genuine Porsche
Suspension OEM-99634351701EM0 Support ring Brand: Genuine Porsche
Tools & Misc 996-721-151-00-M100 Factory Tow Hook, 911 Carrera 2/4 (1995-04), 911 Turbo (2001-05), Boxster/Boxster S (1997-04), 924/924S/924 Turbo all, each
Tools & Misc PEL-TOL-P222 Magnetic Box V Wrench (17mm)
Tools & Misc PEL-TOL-ST0229 16mm XZN Triple Square (Tamper Proof) Drain Plug Removal Tool for 5-Speed Manual Transmission, 1/2 in drive, Boxster (1997-04)
Tools & Misc PEL-TOL-T136 Clutch Alignment Tool, (Spline count = 23; Pilot diameter = 14.9 mm; Spline diameter = 23.8 mm)
Tools & Misc SCHW-P-648 Fuel Line Pliers (adjustable), fits newer BMW, Audi/VW, Porsche
Tools & Misc PEL-IMS-1 Pelican M96 Intermediate Shaft Bearing (IMS) Retrofit Kit, for either Single or Dual Row IMS
Tools & Misc LN-106-08-13 LN Engineering Intermediate Shaft Bearing (IMS) Puller/Counterstay, for extraction of single or dual-row bearing intermediate shaft bearings safely. Includes: puller, driver, 5 chain and 3 chain engine cam locks, TDC lock pin, and broken stud easy-out.
Tools & Misc PEL-0100 European Power Bleeder Kit, Porsche All
Tools & Misc 005773-0-M84 17mm Transmission Drain Plug Removal Tool (3/8 inch drive)
Wheels & Axles 016-409-399-B-M5213 Seal for Differential Output Shaft (45 x 60 x 8 mm)
Wheels & Axles 900-041-013-01-OEM Circlip - CV Joint (sold per each, 2 per axle), Boxster (1997-2003), Expandable Oil Return Tube Circlip (for 2 piece tube, sold per each, 4 required), 911/911 Turbo (1974-89)
Wheels & Axles 911-332-257-00-M395 CV Boot Clamp, 73mm (sold per each), 911 (1985-89), 911 Carrera 4 front inner and rear (1989-98), 928 (1982-95), 911 Turbo (1991-94), 944S2/Turbo, 996 (1999-02), 996 Turbo rear (2001-05), Boxster (1997-02), Boxster S (2000-04), 987 Boxster/Boxster S (2005- )
Wheels & Axles 928-332-257-01-M395 Axle Boot Clamp (34 mm), 911 (1985-98), 928 (1982-95), 911 Turbo (1991-94), 944S2/Turbo, 996 (1999-02), 996 Turbo rear (2001-05), Boxster (1997-02), Boxster S (2000-04), 987 Boxster/Boxster S (2005- )
Wheels & Axles 928-332-293-02-M60 CV Joint Boot, Inner or Outer (sold per each)
Wheels & Axles 951-332-901-00-M60 CV Joint Kit w/boot (25 splines), 944S2/968 All, 944 Turbo from 88, Boxster (1997-02)
Wheels & Axles 964-332-267-01-OEM CV Joint Splined End Cap
Wheels & Axles 996-332-257-00-M395 CLIP
Wheels & Axles 996-332-957-00-M395 Axle Boot Clamp (70.8 - 74 mm), Rear Inner/Outer
Wheels & Axles 999-053-041-04-M34 Wheel Bearing
Wheels & Axles 999-084-641-01-M100 Hub Tension Flange Nut, M22 x 1.5, front or rear (sold per each)
