Old 08-19-2012, 12:28 AM   #4
Spinnaker
Spinnaker's Avatar
Originally Posted by Ricey View Post
How can I test the fuel pump?
I read on a thread here once that if you take off the gas cap and listen in the filler neck, you can hear the fuel pump making a whirring noise, if you let someone else turn on the ignition without starting the engine while you listen.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
