My 99 was sitting in the garage for 2 weeks and would not start. Could not smell gas out the exhaust after cranking the engine. So, I replaced the fuel pump and engine started. I did not check pressure, just went on to replace pump. I just went with the idea that fuel pumps go bad around 100k. I was at 90k. At $200.00 I took the gamble and won. Good luck with the change out.
