Originally Posted by tonycarreon
don't get either of those... xW30 is not a good idea. they do generally keep the 10w40 M1 in the 5qt jugs though.
Why is that? What is it about thicker oil that you find so appealing? Is it the higher pressure? To each his own, I want as much flow as possible as soon as possible. I could care less if the lifters and tensioners take a split second longer to pressurize (which I've not found to be the case). I want 10lbs of pressure per 1000rpm no more, no less...
