Old 11-13-2005, 06:48 AM   #2
donv
donv's Avatar
I have a 986, but it may be the same deal? The sound level is speed controlled. You can vary the degree to which it adjusts or just turn it off using a control on the radio. On the 986, you press and hold the button that has an outline of a downwards arrow on it for over 8 seconds, which will bring up a user menu. You use the tuning knob to select the option "GAL" and then the buttons for left and right arrows that align with two of the tuning presets raise and lower the setting. A 00 is no volume control, a 07 is the max.
I was playing with this the other day and an 07 is too much, I found it very annoying. A lower setting was much better and I preferred it to having it turned off.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
