Old 08-17-2012, 05:26 AM   #13
shadrach74
If the steering wheel is steady going down the road & you brake causing the steering wheel to shimmy then you have a rotor problem. Look for new wheel weights on the inside of the wheels to see if the tires were balanced when installed.
Not necessarily, I have seen suspension issues (loose tie rod) cause a shimmy under braking. If you get no pulse in the pedal, but the steering shimmies, it could be suspension related.
shadrach74 is offline   Reply With Quote
