Old 08-16-2012, 09:38 AM   #4
shadrach74
Squeaks typically come from pads vibrating at high frequency. This issue can often be solved by applying a thin layer of Permatex "Disk Brake Quiet" where the brake piston contacts the pad. Most modern pad set-ups have a thin soft shim on the back of the pad designed to isolate the pad from the caliper. It's not always enough. Don't go overboard with this stuff, use just enoug to form a thin layer between pad and piston...
shadrach74 is offline   Reply With Quote
