Old 08-16-2012, 06:31 AM   #12
IMACMAN
All Done
Thanks for the response, I Took it to my P Mechanic ( Very hard to find up here in Newfoundland... and his shop is busy with some Targa Racing work for some clients.)
They were very familiar with the issue, they put it up on the lift, and injected the grease, and also did rust check treatments on both left & right suspension parts. It only took a few minutes, didn't charge me anything for it, and it worked perfectly.
I decided to replace the parts on both sides, so I had them order in the arms... they were only $85 each, so I figured it's just as well to replace them both... it will also be an opportunity to check/torque/tighten the front end as long as they have it up in the air.
About a month ago, I had a bad "Knock" on the right Rear, so I had it looked at and the right rear shock was blown, so I had them replace the rear shocks. They installed Bilsteins... was a bit pricey for the shocks... but was well worth it no more Knock/Bang and the ride is great. Replacing the rear shocks was not easy, without the "Porsche Shop Compressing Tool thing-a-ma-bob"... to too big dudes to remove & install them.
Paul
IMACMAN, Newfoundland 99,986 Triple Bl
IMACMAN is offline   Reply With Quote
