If the story is ture. The immobilizer box under the front seat is probably fried. Worst case $1000.00 fix by the local 'stealer'. Might be able to get running with a can of denatured alcohol soak, clean and dry the circuit board and replace the mini fuse. $10.00 fix, $20.00 if you need the socket to get get the seat out! Been there done that!
