Old 08-14-2012, 07:41 AM   #1
Homeboy981
Homeboy981
Homeboy981's Avatar
Originally Posted by Mighty Shilling View Post
My 2002 Boxster S learned a new trick recently. Basically, I turn right, and the seat bottom tilts. Seems a tad odd, but its intermittent. Just want to know if anyone has experienced this before I tear into it. Thanks!
You may try to check the "flipper" handle in the seat adjustment area on the lower cushion, on the side by the door, near the front. It is the FIRST ONE and the handle is at a different angle than the others (it has a horizontal orientation). You know the handle, in manual mode, you lift up on it WHILE applying pressure with your butt to the seat in the direction/height you want it to go. Something maybe be stuck inside….of the seat! You might try some lubrication, if not it may be a problem with the brackets underneath that support this function.
Couldn't resist but hope it helps.
