Old 08-13-2012, 12:50 PM   #1
986Porsche986
Can anyone explain these codes??
These four codes came up after a loss of power. Not sure what was
the cause other than possibly bad fuel.
(see this earlier post)
http://986forum.com/forums/general-discussions/36771-bad-fuel-symptons.html
P1125 - Oxygen sensing adaptation, upper load range, cyl. 1 - 3
Short to ground / below lower limit / lean mixture threshold
Short to B+ / above upper limit / rich mixture threshold
P1126 - Oxygen sensing adaptation, lower load range, cyl. 1 - 3
P1132 - Oxygen sensing adaptation, upper load range, cyl. 4 - 6
P1133 - Oxygen sensing adaptation, lower load range, cyl. 4 - 6
Would a failing fuel pump trigger any codes?
986Porsche986 is offline   Reply With Quote
