Old 08-12-2012, 07:54 PM   #2
ppbon
ppbon's Avatar
Question High idle means ...
... more air is coming through the throttle body.
You either have an air leak in one of the rubber connectors or the idle control valve is dirty and stuck open.
Happy Boxstering
Pedro
Originally Posted by sloracer92 View Post
Thanks for the quick response JAAY. I went down to the garage to double check the throttle cable and it appears to me that the cable is seated correctly. I am convinced that it must be some sort of vacuum problem now, but I can't imagine what me removing and replacing the vacuum tube to the change over valve would have changed!
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
