I agree that it cant be the PS as that is located on the wrong side to where I have the leak. The leak is only on both the inside as well as the outside of the bottom cover and it measures around 15 x 20 cm. It also sensitive to UV light, but I am not sure if that is the leak or the dye that I put with the refrigerant when the a/c system was recharged. The strange this is that all the wet part glows under UV light. Will post some pics later today.
