Yes, you need the 10 and 11mm flare wrenches. 11 for bleed nipples and 10 for the brake line fitting. Or the other way around but, whatever, you need both.
Unfortunately they come 10-12 and 9-11. I haven't seen a 10-11.
+1 on quality wrenches as the cheap ones will spread under load. I picked up a 5 piece set of Snap-on through Ebay for about a hundred bucks - worth every penny!
'99 black 986
