Old 08-09-2012, 05:33 PM   #1
Chief
What kind of oil? WD40? Recommendation welcome.
If the window is making a screeching/grinding noise when it goes up and down, try this. On the underside of the door there are 4 rubber access plugs for the window mechanism. Take them out and you will see 2 plastic pulleys. Squirt oil onto the bearing/bushing of the pulley and actuate window and repeat.
If it works, you fixed the window in less than 15 minutes.
02 Tacoma TRD
99 Boxster
Chief is offline   Reply With Quote
