			Yes, the top does install with the soft top down.  It is very simple to install and does not take much time - I've done it alone many times; but, it is easier with help due to the size.  Essentially, one just lines up the front tabs with the top of the windshield and then lowers the top onto the spinlocks just behind the seats near the side of the car.  Then, one locks down the two rear mounting points (spinlocks) and single mounting point in the front where the soft top attaches.  Please note you would need to purchase and install spinlocks on your car if they are not already installed.  In regards to the defroster, there is a plug on the drivers side behind the seat that the defroster plugs into, you can see the cable on the bottom right side of the last picture.  There is a small cover/tab on the vehicle you pop open to plug it in.  I am not sure of the actual weight but have heard it is around 55 lbs.  It should fit all 986 models.  Please let me know if there are any other questions.Thanks
