Old 08-06-2012, 08:56 PM   #2
panameras
Originally Posted by dan.oneufer View Post
Can you explain the resulting behavior:
Will the fogs illuminate at full brightness?
Will the fogs come on when the ignition is on--regardless of the switch position?
Will the fogs remain on when that side's turn signal is flashing?
Will the fogs remain on when the headlights are on?
Here is a quote from the above link:
"be aware that the fog lights will always be on and:
- when you turn the key on the fog lights will come on, prior to cranking the engine. This can be your new battery level indicator; if the fog lights dim much when you crank, then your battery needs charging.
- when you turn on your low beams the fog lights will still be on, so you have both your low beams and fog lights on.
- it is very easy to remove
- easy enough to add a switch to be able to turn on/off this new MOD"
panameras is offline   Reply With Quote
