Old 08-06-2012, 09:31 PM   #16
Gilles
Originally Posted by pk2 View Post
There a re a number of (piggy back) boxes out there that will work fine if not far better. The original didn't really do a 'elluva lot. It just read a handful of sensors ( 0 - 5v) did some rudimentary load calculations and pulsed the 7th injector accordingly.
A newer box can do much more and do it much better. I was told you can install larger injectors, skip the #7, and drive them all with the right piggy back. It can also retard the timing, drive methanol/h2o injection (inter-cooling). you can also add more inputs for even better control.
Regards, PK
How hard would be to adapt a Mega Squirt to properly work with a FI P engine?
Can you find the base maps to get you started..?
