Originally Posted by tommy583
No i don't have a CEL. I used an Actron scanner and found no pending codes. I have a hesitation at full throttle over 5,000 RPM's. I had another thread on the site about it. I have changed the plugs, fuel filter and air filter. It has not improved. I figured it was free to disconnect the MAF to see if it made any improvements. I just don't want to leave it disconnected for too long and have it cause any damage to anything else. Cats, O2 sensors or anything.
Most will agree, that disconnecting the maf for a brief ride is a safe and effective way to rule out the sensor as being the culprit. Provided, however, that it is in fact the sensor that's causing the problem .
