Old 08-05-2012, 11:09 AM   #1
panameras
If all you want to do is to use the fog lights as DRL's, then follow this simple procedure:
Required Materials:
(10) inches of 16 gauge insulated wire
(2) Fuse taps, Radio Shack P/N 270-1204
(2) female Quick Disconnectors, Radio Shack P/N 64-3131
Procedure:
1. Strip the wire ends and crimp on the Quick Disconnects.
2. Plug in a fuse tap to each of the Quick Disconnects.
3. Locate the Fog light relay in the panel above the Fuse panel. It is #12, the far left relay in the second row from the bottom.
4. Attach one of the fuse taps to pin 86 of the relay. Bend the tap to conform to the bottom of the relay. Use a piece of electrical tape to hold the wire to the side of the relay.
5. Return the relay to position #12 and run the other end of the wire to the top of the fuse panel.
6. Remove the Fog light fuse, 25 Amp, #7 (top row, 4th position from the right) from the fuse panel. Slip the fuse tap on the wire end to the upper leg of the fuse.
7. Return the fuse with the tap up into position #7.
You're done.
Thanks for the post. I found the thread from ppbb you are referring to:Daylight Running Lights using Fog Lights - repost, tx Rich in CT
My problem (as posted in the OP) is that relay #12 is missing in my Australian spec Boxster. It's the empty socket to the left of the pink/white relay in the picture, see:
Anyone has any ideas?
panameras is offline   Reply With Quote
