					Originally Posted by The Radium King  .......................................
 ps - sniff your oil!!! gas in oil apparently can facilitate ims breakdown (gas acts as a solvent to scour grease and oil from the bearing i guess). a dripping injector, coupled with not running your engine long/hard enough to burn the gas out of the oil (hence the rumoured trend of ims failure happening more to cars driven lightly or with a long interval between oil changes) could create these conditions.
Sniff the oil is good advice (an artical I read a while ago):
What's that smell?
Glad to hear you've solved the problem.
Regards,
paul...
