Thread: 3.6 vs 3.8
Old 08-01-2012, 09:48 AM   #3
BYprodriver
BYprodriver's Avatar
hi; looking at 3.6 and 3.8 motors and wondering the differences (beisdes the obvious). the bottom end for both has the same part number, so the only difference should be bore and heads. is there much difference in heads - are they interchangeable? also, lne will take a 3.6 to 3.8, and a 3.8 to 4.0. if the cylinders were the same with just different bore, one would think that lne could take the 3.6 to 4.0, unless i am missing something.
any help with understanding would be great, or a point to a place where perhaps i could find this info.
I believe the cases are basically the same, however some have more "meat" allowing the additional 2mm overbore past the usual 99mm. All LN 99mm bore engines use the OEM 997 3.8 head gasket. I have not built a MKII 3.6 engine yet so I'm not sure about head interchange yet but I would start by comparing part# of heads & valves.
