silver trim around gaiter
Homeboy thanks.Linklaw and I are probably looking for the same paint. I don't have pics but the part I'm describing was an option in certain trim packages, possibly "sport design". At the base of the leather shift boot is a silver painted (?aluminum look) horseshoe-shaped piece of plastic glued to the leather where it meets the center console, which piece may be also plastic welded through the leather to the similar piece of plastic on the Inside of the leather boot. The latter piece on the inside is common to all our shifters, since it has the prongs that hold the shift boot to the console. On my outer piece, the silver paint is bubbling loose. Seems to be a common malady for this part, which I do not believe is available separately. I need to know what paint is best match, and how to prep & apply without damaging or bleeding paint onto the attached leather. I don't think I can remove it from the boot intact. Again, thanks to anyone who can help.
