Old 07-30-2012, 02:22 PM   #13
BYprodriver
BYprodriver's Avatar
Originally Posted by jaykay View Post
That might be the one...it was in winter when I last looked into it. the dgauge gives you two externals.
It may be stuck in a water jacket next to an oil gallery....water temp in two different places.....who knows. Trying running your durametric with ECU info tab open and call up engine temp and oil temp. The oil one lags behind but this from cold to 180 while idling....I will have to do one driving.
What should one expect to see for oil temperature? I would think itwould lag like I saw and then overtake water temp.I have massive 2L deep sump so that may sku the readings for a while anyway
I agree with your "bold" statement & theorize that the harder you load the engine the greater the oil temp over coolant temp rising to maybe 40 degrees differential. Just my working theory though.
