Old 07-30-2012, 12:47 PM   #120
AndyA6
Carnut
AndyA6's Avatar
the aos took me as long as fitting the plenum. get a heat gun and get the heat to it - it responds well to heat. a bit of meticulousness and you will get a perfect fit. the clips at each end of the aos tube don't like shear load (only tension) so make sure you form properly for the clips to hold.
looking good; you can be first to report perceived benefits.
Thanks for the tip! And yes, hopefully there will be some gains, let's see
'14 Boxster
