i understand that brakes are air cooled. however the airflow cools the whole assembly and not just the pads. these shields isolate the pads from the rest of the assembly, so if the pads can't radiate heat into the rest of the assembly to be cooled by the air (and, i understand, to not transfer the heat into the brake fluid) where does the heat go? the pads can't hold it all. i suspect snake juice and the heat will get into the assembly regardless of whatever titanum doodads you put in it's way, and beware your brake fluid. titanium whatever can't make heat dissappear.
