Old 07-29-2012, 05:15 PM   #1
RichHawk
2.7L Boxster engine and accessories parts
1997-2004 2.7L Boxster Engine parts.
Pics here on Pelican:
Classifieds - July/August 2012 - Pelican Parts Technical BBS
These parts were removed from a 2002 Boxster engine that started making an engine noise, so the whole engine was replaced with a low mileage used engine. All of these parts ( unless noted otherwise) came off a 75K mile 2.7L Boxster engine that was religiously maintained, and completely stock. Many of these parts fit the 911 996 models too. Anything not perfect I tried to picture and note in the description. Parts are located in Kansas City. Actual shipping costs are the buyer’s responsibility. All parts are for sale as listed, or best offer. Please PM me with your zip code for shipping prices.
I’ve tried to accurately depict what years of Boxsters these parts fit. But Please check yourself. I’m not an expert on changes year to year.
Pics below:
Internal Hard parts (Heads cases, cams, crank ext will be posted next week.)
Thanks, Richard S.
1997-2004 2.7L Boxster Oil Cooler 996-107-025-07
Good condition, no leaks, no damage. Came off a running engine, but could use a good cleaning.
$75 OBO
New this is $200 from Pelican
1997-2004 2.7L Boxster Belt Tensioner Housing, Tensioner spring, and Pulley 996-102-160-3R
Tensioner and housing are in good condition, the pulley turns free, no damage. $60
Tensioner spring new is $80, and new Pulley is $93, you get both plus the aluminum housing for less than half.
1997-2004 2.7L Boxster Engine mount 987-375-123-04 low miles, great condition.
$50
These are $142 new from Pelican
This is a 24K mile Mount removed from the donor 2001 engine. We, had just put a new one on our 2002 months before the engine started making noise.
1997-2004 2.7L Boxster Idler pulley 996-102-120-55
Good condition, rotates freely without any side play of funny noises. Includes the inner race spacer, and the bolt.
$25
New it’s $80 for the pulley alone.
1997-2004 2.7L Boxster Intake Manifolds Left and Right. Perfect condition, includes the one crossover pipe, vacuum actuator, and the rubber sleeves to attach to the T tube. Does not include the throttle body or Throttle body T tube (see the other listings for those)
$70
The cheapest on Ebay has these for $100
1997-2004 2.7L Boxster Throttle Body. 986 605 511 01 Perfect working condition, includes the one T Tube and throttle body itself. Works great. No issues.
$125
The cheapest on Ebay has these for $200
1997-2004 2.7L Boxster Alternator. Works great, turns smooth, no issues or damage.
$70
1997-2004 2.7L Boxster oil filler tube. Hey look, it’s a tube, and ya pour oil through it! No cracks, no damage.
$10
1997-2004 2.7L Boxster Oil air Seperator
Used, But works Good
$25
Oil air Seperator Tube 996 110 137 01 These are easy to break when doing an OAS change out. This one is in good condition, no breaks or cracks, the clips work fine.
$25 (For the tube with the Y flex connector)
Pelican says it’s been replaced with 99611013702. It sells for $45 new on pelican
The other one (no Y) doesn’t have a part number
$25 for it too
1997-2004 2.7L Boxster engine wiring harness. From a Manual transmission car ( I’m not sure if the automatics are different). Completely stock, not molested, all the connections are intact.
$200
1997-2004 2.7L Boxster AC Compressor. Came off the 75,000 mile 2002 engine. Includes the lines, the clutch and pulley. Clutch and compressor both spin as expected, it worked just fine when removed,
Denso part number 447220
$200
Pelican replacement is 996-126-011-BX-M11 and sells for $480
1997-2004 2.7L Boxster Power Steering pump. We never had to add any PS Fluid, but a buildup of gunk shows a very slight weeping around the one of the fittings. Works great.
$75
Pelican replacement is $400 996-314-050-02-M37
1997-2004 2.7L Boxster Power Steering reservoir. 0ff the 2002 75K engine. No damage includes the cap.
SOLD
1997-2004 2.7L Boxster Power Steering pulley. No damage, straight and true.
$20
2001-2004 2.7L Boxster and Boxster S White fuel injectors and Injector fuel rails, pressure regulator, and return line. Note: these are different from the 1997-2000 Boxster S Green injectors. The fuel rail includes the return line, and will fit 1997-2001
These came off the 2001 engine with only 24K miles. These are practically new.
$500 for the whole set (6 injectors two rails, regulator, and return line)
Replacement injectors from Pelican run $300 per injector 996-606-122-00-OEM
I’m thinking I’ll keep them as spares unless someone needs them more than I do.
1997-2004 2.7L Boxster EGR Valve, Solenoid, Vacuum reservoir, and line. Works good. Off the 75K mile engine.
$75
Cheapest Ebay is $100
1997-2004 2.7L Boxster Power Steering line, Hose Tube. No damage.
$40
Cheapest Ebay is $50
1997-2004 2.7L Boxster ignition coils. Beru Part number 996 602 102 00 All six work just fine. Two of them have torn lips at the very bottom, which didn’t affect their operation.
No damage to the connectors, all six were happily firing before removed from the engine.
$80 for all six
Pelican replacements are 997-602-107-00-M47 and $40 each
1997-2004 2.7L Boxster exhaust manifolds and Catalytic converts. Includes three of the four Oxygen sensors. These are the 24,000 mile cats and sensors off the 2001 engine. The passenger side cat has a small dent in it, and one of the O2 sensors removed. The threads are in good shape. The O2 sensors were working properly, and not throwing codes.
$250 for the pair, including the three O2 sensors
RichHawk is offline   Reply With Quote
