Old 07-29-2012, 04:06 PM   #10
Gforrest2
Gforrest2's Avatar
Originally Posted by SoloBox1 View Post
HELP.... Can anyone tell how to get my speacker wire to the front trunk? I have 04 S with BOSE AMP, trying to bypass and connect to the speaker direct. I ran a couple wires from the unit over the top just to test and they work fine. Just cant see a way from the back of the HU to the FTrunk.
Remove the battery. There is a large rubber plug that leads into the driver's side below the steering wheel. Easy path to the head unit. And to the left of the battery (facing from the front), there is a plug that leads from the battery compartment to the frunk. And there's already a cutout in the carpet for the wires.
I believe this is much easier then running wires directly from the head unit to the speakers. I just did this yesterday. Pulled the harness that attached to the amp. Figured out which pins go to which speakers, and then ran my new speaker wire to these pins (bought male pins, soldered and shrink wrapped, and then inserted these pins into the female plug that used to go to the factory amp).
Glen
Gforrest2 is offline   Reply With Quote
