Thread: Horn Problem
Old 07-27-2012, 07:21 PM   #10
jesseborgelt
My horn started honking when the brakes were applied. I read this forum and found sound advice. I choose to try an alternative that worked and I thought I would share. I removed the two screws and pulled out the airbag. I then loosened the 4 bolts and removed the bracket. I applied a few beads of glue from a hot glue gun around the bushings, allowing it to dry briefly between the two layers. The end result is a fast fix that can immediately be reinstalled. The glue is semi-flexible when dry and is similar to the bushing in my opinion. Total cost under $1.
jesseborgelt is offline   Reply With Quote
