Old 07-26-2012, 09:49 AM   #1
oc-boxster
oc-boxster's Avatar
Originally Posted by l3m View Post
I believe the 'Special Chassis Rigidly Tuned' option is the M030. You can verify this by looking at the option codes label on the underside of the hood. There should be an '030' code listed. If you don't have that code, then you have the standard 'S' suspension.
Ok thanks for the info..I do not have an 030 code listed
oc-boxster is offline   Reply With Quote
