Old 07-25-2012, 03:16 PM   #3
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
First thing in the morning, the starter turns over perfectly, but once the car is hot, the starter initially turns very slowly for a moment, almost like its not going to turn at all. and then goes at normal speed. I was reading in the Rennlist 996 forum that the problem in 911s is a cable going to the starter that doesn't provide enough juice and needs to be replaced according to a TSB. Battery is good, dead cold voltage after sitting overnight is 12.55v
Does the Boxster have the same problem?
I had a car that experienced this same problem, ended up being a worn out starter.
The windings in the motor seem to weaken when hot..
I would check all the obvious first, you can get you battery load tested to see if the batteries failing.
I went through all that stuff first..
T
RMS, IMS, 87.5K
